Append record to table in Arcade with calculation attribute rule
1860
09-05-2022 03:22 AM
Bart-JanSchoenmakers
Hello,
Does anyone knows if it is possible with a Calculation Attribute Rule to append a record to another table?
My objective is whenever a point is edited to write a record to a table.
I’ve been looking around the forum and the help and this doesn’t seem possible in Arcade, however it might be that I missed something.
Thanks all,
Bart-Jan Schoenmakers
Statistics Portugal
2 Solutions
JohannesLindner
This is absolutely possible.
Instead of specifying the field for the rule and returning a value, you leave the field empty and return a dictionary. This dictionary has to have a defined structure, which you can find here:
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/attribute-rule-dictionary-k...
A simple example:
// Calculation Attribute Rule
// field: empty
// triggers: insert
return {
    edit: [
        {className: "OtherTable",
            adds: [
                {attributes: {TextField: "Value", IntegerField: 5}}
EDIT: And you can do lots of other things, too. A few examples are listed in this blog post:
Advanced Attribute Rules - Editing features on another class with attribute rules (esri.com)
Have a great day!
Johannes
Hi Johannes,
Thank you for this example and the link of the help.
I easily managed to get an example to work. I only knew the return dictionary for multiple fields, but dictionaries are so much more useful and powerful.  I thought I had to develop a trigger in Oracle.
Bart
JohannesLindner
A simple example:
// field: empty
// triggers: insert
return {
    edit: [
            adds: [
Have a great day!
Johannes
Hi Johannes,
Bart
