Alternative to First
1839
08-18-2021 04:44 PM
ChrisGAEG
Hi there,
I have a rule where I am trying to see if a line intersects a specific polygon. I was using First, but realized the rule wouldn't flag if it went through another polygon first, then intersected my flag polygon. Is there a way to return a list and then flag if my polygon(cab_id == 'SDY-HUT') is in that list? This is the code I am using.
var cabs = FeatureSetByName($datastore, "Proposed_OLT_LCP_Boundaries_copy", ["cab_id"])
var cabsInt = Intersects(cabs, $feature)
var cabSpliceInt = First(cabsInt)
if (cabSpliceInt == null) return {"errorMessage": "Please edit inside a cabinet boundary"}
if (cabSpliceInt.cab_id == 'SDY-HUT')
return false;
else return true;
Thanks!
HusseinNasser2
You can continue using first but first (no pun) you have to add an additional filter against the polygon you want. Push the query all the way to the DB.
var cabs = FeatureSetByName($datastore, "Proposed_OLT_LCP_Boundaries_copy", ["cab_id"], false)
var filteredCabs = filter(cabs, "cab_id='SDY-HUT'")
var cabsInt = Intersects(filteredCabs , $feature)
 return true;
JohannesLindner
// just check the intersected feature set
if (cabsInt == null || Count(cabsInt) == 0) {
// filter cabsInt for your flagged polygon
var sdy_hut = First(Filter(cabsInt, "cab_id = 'SDY-HUT'"))
if (sdy_hut == null) {
  return false
return true
Have a great day!
Johannes
HusseinNasser2
 return true;
ChrisGAEG
Okay great, this makes sense. What is the syntax for using a list in this case? What is the Arcade equivalent of "IN"? I want to do something like the following -
var filteredCabs = filter(cabs, "cab_id IN ('SDY-HUT', 'ESC-C02', 'ESC-C04')")
HusseinNasser2
That statement is correct and should work
p.s. it is not Arcade, it is SQL.
