Access Parent Attribute
456
03-30-2026 11:35 AM
JarredPaquinMC2
Hello,
I am unsure why my following code isn't working.
var related = FeatureSetByRelationshipName($feature, "ACProductsGroundwaterSamplingPoints_ACProductsQuarterlySurveyForm")
return first(related)['WellID']
I am trying to calculate a field in the child table based on the value in the parent table, but it's throwing an error.
Thanks!
KenBuja
MVP Esteemed Contributor
Are you checking whether there are any records in related?
var related = FeatureSetByRelationshipName($feature, "ACProductsGroundwaterSamplingPoints_ACProductsQuarterlySurveyForm");
return IIf(Count(related) > 0, First(related)["WellID"], "No related records");
JarredPaquinMC2
No, unfortunately that's not it. When I try to add a related record to the table using FieldMaps, it's still failing to calculate. Unfortunately FieldMaps does not provide very much in the way of error messages.
