Will ArcReader 10.1 open a 10.2 pmf?
3914
07-31-2013 08:12 AM
TomMagdaleno
I read that one feature in 10.2 is more backwards compatibility.  Is this true for ArcReader?  In the past we had all the users on version 10 and I was on Desktop 10.1.  Every time I wanted to change a pmf I had to go to another computer and do it in ArcMap 10.  Now we have pushed out 10.1 ArcReader.  If I update to Desktop 10.2 will I be right back where I started?
Tom
TomMagdaleno
I found out it will work after calling ESRI and having them check.
MichaelVolz
Esteemed Contributor
Tom:
Do you know if this solution will work between 10.0 and 10.2?
TomMagdaleno
I'm 99% sure that it does not work.  Because it will not work between 10.1 and 10.0.  10.1 was a major change from 10.0.  10.2 is more like a service pack.
