Why does Publisher Extension take so long to publish a map for distribution?
1445
11-06-2019 07:48 AM
CarmaGrime
Utility Map in Desktop 10.5.1 with aerial photography. A couple months ago I pkgd and published this map, it took overnight to process, but it did complete the process and I could open it in ArcReader 10.5.1. Co worker could not open in ArcReader 10.5.1 and gave him errors. Tried ArcReader 10.7.1, same thing. Set it to publish again, been running for 15 hours and is only at 90%.
Tags (1)
MichaelVolz
Esteemed Contributor
Can you try the same process without the aerial photography?  Then just add the aerial photography to the ArcReader project when you are in ArcReader (add data button or something to that effect).
CarmaGrime
I did remove 2 of the larger aerial photos and it processed in about 2 hours. And I could open it in Arc Reader 10.5.1. Maybe that has been my problem, just too much .sid files.
Thank you.
