Transparency Button
2046
01-25-2011 02:33 PM
TedCronin
When using the Transparency button the Transparency slider, covers the button, when the slider disappears, the place where it covered the button is still the same color as the slider, and the complete button does not show correctly.
Repro:
Select a layer
Click Transparency button
Adjust slider
Let it disappear
view button, lower right corner should show the color of the slider and not the button
JuanLuera
Ted,
This issue seems to be within 10.0.4, in doing some testing where I was able to reproduce it. In doing further testing within 10.1 final, we found this issue was resolved.  Gracias!
JanuszStozek1
Do you by any chance have the sample code that does this behaviour?
Any chance you have a solution for swipe layers?
I can't seem to get it work..
