Publishing Scales
4456
06-25-2013 12:12 PM
PhilHasty
Our engineer likes certain scales. How can I get a .pmf arcreader map to publish with the scales I want? My .mxd are already set via a text file I have loaded and referenced.
BTW, I searched for scales and did not anything that applies to this.
Thanks, Phil.
DavidLuke
You must check out Online" rel="nofollow" target="_blank">http://www.myscalestore.com]Online Scale Providers to select a best scale for you.
I have been purchasing scales here and i always find it fit fir my every need.
Try it..!
TimotheeBecker
Hello,
I have the same question, in ArcGIS 10.0
How to publish an Mxd with predefined scales that would open in ArcReader and have drop down scale menu with these scales ?
Possible ?
If not, is it possible to configure ArcReader's drop down scale menu ?
MarkBockenhauer
Timothee,
The ArcReader scale drop down list cannot be configured.
It is not possible.
Mark
TomMagdaleno
He can always just punch in the scale he likes.  Just type 50 in the box and it will scale to 1:50.
