Problem Accessing Data Using ArcReader 10.5
1404
07-26-2017 10:50 AM
EricErickson
I've got a master directory on a remote drive that contains a pile of shapefiles and a subdirectory containing data in mdb format, and a directory containing imagery. I've been creating and publishing ArcReader maps in that master directory for years and had no problem viewing the data in AR. But once I updated to AR 10.5, the imagery and the layers in the mdb file are 'inaccessible' in ArcReader.
The maps are quite large and creating a data package takes forever, and then some. I prefer to just publish the map using the local data.
Has anybody experienced this behavior with AR 10.5?
Eric
JayantaPoddar
ArcReader will intended to read Published Map File (PMF). Are you facing difficulty in reading the PMF?
It will not read feature classes/shapefiles/rasters directly from the drive.
Think Location
