print to PDF
3154
12-12-2012 07:32 AM
danbecker
open an aerial image in ArcReader, go to file/print. Select Adobe PDF printer and export the map.
Open the .pdf map in Adobe Acrobat 10 Standard and there are thick White lines across the PDF.
Anyone else have this problem?
OS is Win7 x64.
AndresCastaneda
I have recently come across this issue. I was able to "print to pdf" from the layout view and the artifacts no longer appeared. hope this helps.
kaivendurant
I ' ve been caught in the same problem while printing to PDF with aerial image. So I choose to open pdf map in Foxit pdf reader instead of Adobe Acrobat ,it displays correctly.I don't know why.
DanielHester
We've also run into printing problems in ArcReader 10.1. Our trouble is with a particular floodplain feature class located in an SDE database. It simply takes forever to load! Then, when printing, it takes at least 10 minutes. Does anybody else have this issue/know a solution?
dannyrecthor
i think some imaging processing programmes might be helpful , you can google it or i can give you some advices. I use a PDF printer driver introduced by my friends . Install it and it becomes a selectable printer option. Now you can print PDFs in any program at all, including Adobe Acrobat reader! Just open a PDF, select print, and specify the page range you want to print and select the printer driver.
