Layer Selection Problem in ArcReader
1762
04-05-2011 11:57 AM
CarlWilburn
I have an ArcReader program that brings the published map up fine, but when I select another layer to turn on, they all turn on, then when I select one to turn off, they all turn off.  Any Ideas why or what needs to be changed?  I can open the same file on another machine and it works fine.
JuanLuera
Carl,
Have you looked to upgrading overall to the latest version of ArcMap (10.1) with the latest of ArcReader. If you have upgraded to the latest version, are you still seeing the same issue with the layers. Gracias, Carl!
ESRI Customer Care Portal
https://customers.esri.com/index.cfm?event=login.show
