Converting LatLng coordinates to point shapefile.
1823
03-24-2011 06:27 AM
MustafaNoor
I have more than 50,000 LatLng coordinates defined under SWREFF99 1800 projection. I want to know, is it possible to convert these coordinates into Point shapefile ? if yes, then how can i do this ?
JuanLuera
Hola Mustafa,
I am assuming you are attempting to do this within ArcMap, simply because ArcReader is that, a viewer of your published data. If you are looking to do this within ArcMap, I am including a technical article, which walks you through the work flow. Gracias, Mustafa!
HowTo:  Import XY data tables to ArcMap and convert the data to a shapefile
http://support.esri.com/en/knowledgebase/techarticles/detail/27589
