Export as something other than BMP?
3624
09-20-2012 09:34 AM
StacySalinas
I need to be able to export my map from ArcReader as something better than a BMP. PNG or JPG is preferred. Does anyone know of some type of plug-in or extension that can make this possible? I found a program called Image Printer Pro that will but it is not free and we are ending our fiscal year so spending any money right now is next to impossible.
LucasDanzinger
Esri Frequent Contributor
You could try searching for a PDF Printer. It won't give you a PNG or JPG, however.
JanuszStozek
If you have Adobe Reader pro/standard installed, you should be able take the .bmp file and convert to other format supported by Adobe application. If you have print function in your custom ArcReader you should be able to print to .pdf file directly since that comes with Adobe installation.
If you want to be even more creative you can add reference to the popular photo program that is used at work and export map using the program's object. That is more advanced programming.
