Data in ArcReader doesn't line up
2085
12-20-2012 06:44 AM
AniekanEkaette
After publishing to a pmf file I noticed the data (roads & sections) did not line up properly. It however does line up correctly in the .mxd file. Any ideas why this might have happened?
Thanks.
JuanLuera
Hola Aniekan,
I just tested this on our end, and I was able to see several of my data line up within 10.0.5/10.1.1. I would inspect the data bit further, maybe look to adding the same dataset�??s to a new mxd and then re-creating the pmf again. I would also suggest maybe seeing if any other data does the same, which may drop on-top of each other. You are always welcome to log a webform with Support Services, with being current with your maintenance. Gracias, Aniekan!
Support Service
1-888-377-4575
http://support.esri.com/en/webform/s...275/chat/false
