ArcReader
2238
5
07-13-2010 07:56 AM
JimGrove
I have published and packaged a map in 9.3.1. It opens fine from the network and from my hard drive but when it is loaded to a laptop all layers have red explanation marks. The pmf and data folders are fine. Any help will be much appreciated.
Jim
MattMorris
The red exclamation marks indicate broken data links. The path to the data your pmf is using is not intact on the laptop. You can recreate it on the laptop (keep path intact by duplicating data and location) or create a data package in Arc Publisher for the pmf to use.
CurtisCockburn
I too have the same issue.   When I create a pmf and package the data, it will work fine on my pc but when I load it on to another it will show several layers with red exclamation marks.
I have not had this difficulty with previous pmf's but this one is rather large and I wonder if that may be it?
Does Publisher have certain limits?
zonsun
I came across the same problem. Also with a raher large MXD and PMF. Does anyone have a solution yet?
greetings,
Zon
RobbHodges
ditto for me...and I am only having this issue on certain machines.
jessebelcher
Guys this is your answer... I fix this one of 2 ways one is to make a data package. And make sure your set relative paths is selected.. The other is to copy all the data over with your .pmf.. I would just make a data package.
