ArcReader and Mosaic Dataset
6352
6
01-12-2012 07:25 AM
PCMPCM
Using ArcGIS DT 10 SP3, I've published an mxd containing a Mosaic Dataset.
When I open the pmf the Image is missing (red exlamation point) while the Footprint and Boundary are visible (ArcReader 10 SP3).
Is the Mosaic Dataset supported in ArcReader?
Fabrizio
AGruber
I am having the same issue.  Can anyone offer any suggestions?
Thank you,
Angie
EvaShoemaker-Maffei
Was a solution ever found for this?  I have a raster catalog and when the pmf is opened - the wireframe is the only display.
JanuszStozek
Is the mosaic dataset pointing to the right raster catalog geodatabase? When the Raster catalog was created, is it linked source pointing to the rasters images somewhere on the network or locally? or are the raster images embedded as part of the raster catalog geodatabase? Has it moved and/or are the links broken? Are the links to it are absolute or relative paths?
I have no problem seeing it on ArcReader 10.1 or my custom Built ArcReader.
CharlesRobbins2
This is still an issue, I guess I need to simply upgrade to 10.2 and all my problems will go away.:mad:
AndréReinlert
Hi
Currently running arc 10.2.1 and trying to create an arcreader product incl a bunch of raster mosaic datasets. There are still problems. Got error message when the mosaic datasets are incl, if i remove them it all works. So the issue of mosaic datasets inside arcreader is still a unsolved issue
Thanks
andré
AlexBellis
Hi
I am using ArcMap 10.2.1 and seem to still be having the same issue when trying to publish a map which includes mosaic datasets to ArcReader - does anyone know if this has been resolved yet?
Thanks
Alex
