Why doesn't this work?
1880
5
04-14-2010 10:00 AM
DouglasBurn
I've created a button on an editform to delete the selected feature.  Here's the code that is called when the button is clicked:
Sub DeleteSighting
Dim objSightingsLayer
Dim objSelectedLayer
Set objSelectedLayer = Map.SelectionLayer
if objSelectedLayer is Nothing then
  msgBox("No feature is selected!")
  exit Sub
else
  Set objSightingsLayer = map.layers("Sightings")
  objSightingsLayer.Forms("EditForm").Close
  Application.ExecuteCommand("featuredelete")
end if
End Sub
When I click the button, the form closes, and the ArcPad dialog box asks me if I want to delete the selected feature.  However, when I say "yes," the feature is not deleted, and it becomes unselected.  If I select the feature and then use the "Delete Feature" command from the drawing tools menu, the feature is deleted as expected.  Any idea why the "delete feature" command doesn't work from my edit form?
Tags (3)
BillCrawford
I'm no coder but,
Should deleting come before closing in your code?
DouglasBurn
that the form should be closed first, before deleting the feature. But it was easy to move the ExecuteCommand statement in front of the form close statement.  Unfortunately, that doesn't work, either.
BillCrawford
Any way to view the code for ESRI's "Delete Feature" button in Arcpad for any tips?
MattCooper
I think you might need to change your command name to "delete" instead of "featuredelete".  It's strange that it asks you to confirm the delete command though since "featuredelete" doesn't appear in the list of valid commands in the ArcPad developers help.
Matt
RolfBroch
Since you have an editform open you must by definition have a selected object.
If you want to delete this object you can have a command button that sets a global boolean and then close the Editform and then in the onunload routine delete the object. The following subs contain the code (I have not tested it)
Sub cmdDeleteButtonClicked()
  g_bDelete = True
  Editform.Close False
End If
Sub EditForm_OnUnLoad()
  If g_bDelete Then
    Application.ExecuteCommand("Delete")
  End If
  g_bDelete = False
End Sub
Rolf
