Using a Real Time GNSS Network with ArcPad
1085
10-08-2013 12:44 PM
HeathConsultants
I have been using ArcPad with Trimble Positions to collect and post-process GPS Data.  I now have access to do real time correction with a GNSS network.  I have been trying to get this work for a couple of days now and am not getting anywhere.
Can I even use this with ArcPad?
Tags (3)
PaulLohr
Real time as in a continuously operating reference station? If this is what you are after, pretty sure you will need the Trimble GPSCorrect extension. Horizontal positions should be ok but vertical positions can be a problem because ArcPad does not use a geoid. Just in case that's where you are headed.
Paul Lohr
Lohr Geospatial Services, Inc.
AlisonWalker
You can certainly use a real-time network with ArcPad and the Trimble Positions extension for ArcPad.  You just need to get into Positions on the handheld and go into the real-time settings.  Probably will have to set your Choice 1 to Internet if you are trying to connect directly from the handheld and then configure the rest with your login information, and that should work.
