update Combobox set to dbf
4781
10
12-17-2010 08:13 AM
JayKappy
I have a project that has a couple dbf tables that are feeding a couple comboboxes.  Whent he app opens the comboboxes are populates with values from the dbf tables.
I then wrote code that allows teh user to update the dbf tables.
THis works and the dbf files are updated ALTHOUGH these changes are not reflecting when the user clicks the comboboxes the next time.  I have to completly leave the application and start it again.
So this points to the fact that the Comboboxes are being populated on the application open...
So my next question is obvious....how can I force the refresh of these comboboxes after the dbf update.
If I was loading the comboboxes when they open no problem...but this is something a bit different...I am using ArcPAD to populate the comboboxes by pointing to a dbf table in the list values tab of the combobox.
Any thoughts?
THanks
Tags (3)
JayKappy
I think I made a owrk around....but for soem reason it takes about 12-15 seconds to refresh the combobox/listbox...there are about 1200 records in the dbf...
Anyoen knwo of a faster way to do this....and this time taken is from a desktop computer...uggggg
EricHajek1
Would using the .AddItem method on the combobox at the same time you're saving the new DBF entries work? Maybe this is already what you're doing, but it would create the illusion that it's refreshing the DBF-based combobox, but really it's the DBF plus the few new entries. The next time ArcPad gets started up, it will load entirely from the DBF and forget the items you added manually, so it would be pretty seamless to the end user.
JayKappy
Yea that is what i decided to do....I was seeign a huge reload time on my PC but for soem reason on the laptop it was only a couple seconds...very confusing because the PC is 10 more powerful than the laptop.
Thanks
ColbyParnell
Jay,  can you post what code you have?  Im trying something similar to what your doing but cant get it to work.
JayKappy
This is what I am doign to refresh the combobox after I update or create a new record in the dbf.
Is this what you are refering to or are you talking about updating the dbf?
I simply call this sub
Note is you are usign the DBF as a lookup table then it has to be in the same folder as the .axf file.   (Where you set it in ArcStudio in the listvalues tab of the control properties of the combobox)
If all you are doing is calling it for a query etc then it can be anywhere...
Sub PopulateListBoxMUTCDPage
  Dim objRS4, objSelLayer4, objEFPageOneControls4, objEditForm4
  Set objSelLayer4 = Map.SelectionLayer
  Set objRS4 = objSelLayer4.Records
  objRS4.Bookmark = Map.SelectionBookmark
  Set objEditForm4 = application.map.layers("Supports").forms("EDITFORM")
  Set objEFPageOneControls4 = objEditForm4.Pages("page3").Controls
   Dim MUTCD_CodeValue
   MUTCD_CodeValue = objEFPageOneControls4("mutcd_code").Value
   'msgbox MUTCD_CodeValue
 objEFPageOneControls4("List1").Clear
' SPECIFY THE PATH TO LOCATE THE DBF FILE FOR QUERYING
 Dim path
    path = "C:\GPS_data_collections\Packets_Outgoing\Support_Signs_Data_Collection_2011\MUTCD_Code.dbf"
    Dim pDS
    Set pDS = Application.CreateAppObject("RecordSet")
  pDS.Open(path)
 pDS.Find("MUTCD_CODE")
 pDS.MoveFirst
 Do While Not pDS.EOF
   Dim Description, ObjectID
   Description = pDS.Fields("MUTCD_CODE").Value
   ObjectID = pDS.Fields("MUTCD_CODE").Value
                   objEFPageOneControls4("List1").AddItem ObjectID, Description
  pDS.MoveNext
 Loop
 pDS.Close
 Set pDS = Nothing
End Sub
WAIT A SECODN I AM CONFUSING MYSELF HERE....THT updates a list box on have on my form...this will update the combobox after saving the record in teh dbf
Call this sub
Sub Save
        ....code to Save or Update the dbf
       Call PopulateMUTCDCodeComboBox
End Sub
Sub PopulateMUTCDCodeComboBox
  Set objEFPageOneControls4 = objEditForm4.Pages("page2").Controls
 objEFPageOneControls4("mutcd_code").Clear
 MsgBox "The MUTCD Code List is Updating, Please hold on!" & vbnewline & "The combobox will populate shortly", vbExclamation, "MUTCD Updating"
 Dim path
 ' Desktop path
    path = "C:\GPS_data_collections\StreetSign_Collection_ArcPAD\Packets_Outgoing\Support_Signs_Data_Collection_2011\MUTCD_Code.dbf"
    Dim pDS
  pDS.Open(path)
 pDS.MoveFirst
   Dim varMUTCDCode
   varMUTCDCode = pDS.Fields("MUTCD_CODE").Value
      objEFPageOneControls4("mutcd_code").AddItem varMUTCDCode, varMUTCDCode
  pDS.MoveNext
 Loop
 pDS.Close
 Set pDS = Nothing
End Sub
RolfBroch
If I read your code correctly it would be easier to use these requests:
objEFPageOneControls4("mutcd_code").AddItemsFromTable path, "MUTCD_CODE", "MUTCD_CODE"
and not do any looping at all.
Rolf
JayKappy
Rolf
Something like this?
Dim path
path = "C:\GPS_data_collections\StreetSign_Collection_ArcPAD\MUTCD_Code.dbf"
RolfBroch
Yep, that looks correct.
JayKappy
Something weird is going on here....Nothing to do with the code...
That code worked by the way, thanks....
  • I have a Windows 7 machine, 64 bit, Intel Core(TM) 2 Duo CPU, 8 gigs of RAM
  • The update and saving takes about 13-15 seconds....
  • I place the same app (ArcPAD) on a Windows XP machine with Dual Core, about 1 gig Ram and it does it in 2-3 seconds....
I have no idea whats going on here....How can my desktop process this so slow and the laptop be so fast?
But anyways I am going to test on the Laptop and see where I am at....THANKS AGAIN.....
