Unable to add axf layer
2529
06-16-2011 02:53 AM
LeiWu
Hi all.
I'm stuck for adding axf layer in Arcpad 10.0. I checked out the data layer for disconnected editing into an axf layer. It works fine when I was adding it using ArcPad for Windows. However, if I copy the axf file into the mobile device and run Arcpad on the mobile, Arcpad can not open the axf file. According to the help document, a red cross over the layer icon indicates the Microsoft SQL Server Compact Edition database engine has not been installed on the device. But I'm very sure that the SQL Server has been installed(And in fact, I've tried reinstalling it manytimes). The screen captures of adding the layer in the device and the list of installed programs have been provided for your reference. I'd be really thankful for your helping me out of this trouble. Thank you very much in advance!
Tags (4)
by Anonymous User
Not applicable
Original User: ivankautter
http://forums.arcgis.com/threads/14015-Bug-Report-Bug-with-axf-Files-Confirmed-in-ArcPad-10
It is likely a known bug that I have attempted to report to ESRI and that it has continued not to address.
