Trimble position check in error
4433
09-02-2014 01:49 PM
LiBai
When I use the trimble position Desktop add-in to check in field data, it has error and says "unable to read beyond the end of the stream." Whether I close the error window or click "continue" button, all the points collected from field will be add in to the empty point layer I made for check out. However, I am not able to see it in the Trimble position desktop dockable window as a check in layer, so I could not do any post process... I attach the image of the error window and the error details in the attachments. Does anyone know what is the problem?
RobCahalan
Did you ever figure this out? I have run into the same thing.
