The coordinate system of *.apm,
3100
09-23-2013 10:33 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
The current coordinate system of my *.apm is ???Palestine_1923_Palestine_Grid???. I wanted to add an image which has ???Israel_TM_Grid??? as its coordinate system but I got the message in the screenshots below
[ATTACH=CONFIG]27679[/ATTACH], [ATTACH=CONFIG]27680[/ATTACH], [ATTACH=CONFIG]27681[/ATTACH]
Does the *.apm require to have all the data to be with same coordinate system?
Thank you
Best
Jamal
Tags (4)
HannahFerrier
Short answer - yes
Longer answer - Your data must be in the same projection to be used in ArcPad. ArcPad can not add layers with different projections to the same map. The only exception to this is StreetMap or ArcGIS Online basemaps. Otherwise, ArcPad does not reproject data on-the-fly. See here for more information.
Hannah 🙂
HannahFerrier
Short answer - yes
Hannah 🙂
by Anonymous User
Not applicable
Short answer - yes
Hannah 🙂
Many thanks Hannah for the help. This is what I wanted to know. Then I�??ll manage to let me data has the same coordinate system
Best
Jamal
