Synchronize to server
1185
09-18-2010 05:19 AM
MarcoWagemakers
I published my data to ArcGIS Server 10 within capabilities for ArcPad. After that I started Arcpad 10, "Add data from server" and requested the data from the server. I edited the layer and added a point and choose finally: "Synchronize data to the server". In the log, there is an error:
15:03:50 Missing AXF_PUBLICATION_FILENAME property
Log file:
15:03:48 Synchronizer process started.
15:03:48 Loading configuration from 'C:\Users\Wagemakers\Documents\My ArcPad\ArcPadSync.apx'
15:03:48 Synchronization thread started
15:03:50 Starting synchronization
15:03:50 Synchronization thread processing
15:03:50 Loading configuration from 'C:\Users\Wagemakers\Documents\My ArcPad\ArcPadSync.apx'
15:03:50 Processing c:\users\wagemakers\documents\meldingenarcpad\.axf ...
15:03:50 Connecting to http://wagemakers-pc/arcgis/services/MeldingenArcpad/MapServer/ArcPad
15:03:50 c:\users\wagemakers\documents\meldingenarcpad\.axf: Missing AXF_PUBLICATION_FILENAME property
15:03:50 0 databases synchronized successfully
15:03:50 Synchronization thread idle
Can someone assist me to synchronize the data to the server?
Marco
Tags (3)
ToddStuber
Hi Marco,
Take a look at your database connections in ArcCatalog.  One of the most common reasons for this error is that the connection is most likely a direct connect.  Try switcing to a 3-tier SDE connection and republish the service.  It should now synchronize correctly.
