Sub types
1323
05-28-2013 08:29 AM
HollieClavering
Quick Question:
Can you create more than one sub type for a feature class?
Hollie
Tags (3)
ThaiTruong
No you can't.  You can only have one subtype per feature class.
You might have to review your feature class to see if there's a way to split them out by feature type, so you can create multiple feature classes.  For example, I have a feature class for utility lines.  My feature class contains both water lines and sewer lines.  Then I would separate them out so I can use the same subtype for both feature classes.
