Solution to Blog Article - How to use ArcPad with SQL - Part 2, UPDATE
3418
11-07-2010 04:11 PM
GarethWalters
Hi there, if you are reading this I am hoping that you have a solution to the homework question I set in the blog article How to use ArcPad with SQL - Part 2, UPDATE.
Write your comments and attach your applet/script for everyone to learn from so they can see how much ArcPad ROCKS!
Tags (3)
EricHajek1
Hi Gareth, I enjoy the blog articles, but I didn't see this one on the ArcPad Team Blog. I just see part 1 of the How to use ArcPad with SQL. Could you provide a link to it? Thanks!
GarethWalters
Hi Eric, you're too fast :). I had to create the forum before I could post the link on the blog.
Here is the link though http://arcpadteam.blogspot.com/2010/11/how-to-use-arcpad-with-sql-part-2_08.html
Cheers,
Gareth
