Size limitation to a vbs ArcScript?
1665
07-12-2012 08:05 PM
DanikBourdeau
Just wondering if anybody has come across any issues using very large vbs scripts?  Mine is just about to top 1000 lines and it got me wondering if I should be concerned.
I may be wrong but as far as I can figure out you can only have 1 script per applet, is this correct?
Thanks
Tags (3)
RolfBroch
I have not found a size limitation to the vbscript files. The largest I have used are over 10 000 lines of code.
I have also found that in the pc environment, the following link is useful:
http://forums.esri.com/Thread.asp?c=34&f=1180&t=87072
This is quite handy if you have developed a library of routines that you would like to use in several projects (for ex. routines for reading and writing xml files)
The short version is this:
' "Include" routine for Windows VBScript
Sub Include(sIncludeFileName)
  On Error Resume Next
  Dim pFSO, fInclude, sScript
  Set pFSO = CreateObject("Scripting.FileSystemObject")
  If pFSO.FileExists(sIncludeFileName) Then
    Set fInclude = pFSO.OpenTextFile(sIncludeFileName)
    sScript = fInclude.ReadAll
    fInclude.Close
    ExecuteGlobal sScript
  End If
  Set pFSO = Nothing
  Set fInclude = Nothing
End Sub
RolfBroch
    fInclude.Close
  End If
  Set pFSO = Nothing
End Sub
DanikBourdeau
Hey Rolf,
10 000 lines of code! I should be good for a while 😉
That's an awesome snippet of code, thanks!  I've put it in my little vault.
