SELECT WHERE statement
6116
12
08-16-2010 09:40 AM
JayKappy
I can get this query to work...but its quering a Double Field (ANGLE):
' Build Query Statement
Dim varQuery
varQuery = "SELECT OBJECTID FROM SIGNS_STANDALONETABLE WHERE ANGLE = 270"
' Set up recordset query
Dim  pRS6
Set pRS6 = pDS6.Execute(varQuery)
' Move first
pRS6.MoveFirst
Do While Not pRS6.EOF
 Dim MaxID, MaxID2
 MaxID = pRS6.Fields("OBJECTID").Value
 MaxID2 = MaxID2 & ", " & MaxID
 pRs6.MoveNext
Loop
msgbox "Max ID: " & MaxID2
But I need to query a string field and I cant get that to work....this is what I was trying:
ID is a text field in the table
varQuery = "SELECT OBJECTID FROM SIGNS_STANDALONETABLE WHERE ID = "01NW-001" "
I then wrote it to a variable and tried this:
Dim varUniqueID
varUniqueID = "01NW-001"
varQuery = "SELECT OBJECTID FROM SIGNS_STANDALONETABLE WHERE ID = " & varUniqueID & " "
neither works....any thoughts?
THanks in advance....
Tags (3)
JayKappy
OH man do i feel stupid....OK the query seems to be workign now although back in ArcMap I am not zoomed to full extent therefore not all of my data is being exported...I think this is that last issue...
JayKappy
Last question...
How do I get this to work with a varaible...I tried this:
varQuery = "SELECT * FROM SIGNS_STANDALONETABLE WHERE Support_ID1 = " & varUniqueID & " "
and This
varQuery = "SELECT * FROM SIGNS_STANDALONETABLE WHERE Support_ID1 = ' & varUniqueID & ' "
and This
varQuery = "SELECT * FROM SIGNS_STANDALONETABLE WHERE Support_ID1 = ' " & varUniqueID & " '  "
JayKappy
I swear ArcpAD is really flaky....
varQuery = "SELECT * FROM SIGNS_STANDALONETABLE WHERE SUUPORT_ID1 = '"& varSupportID &"' "
This now works...and was one of my previous attempts that didnt.....
THANK YOU ALL FOR YOUR HELP....VERY APPRECIATED... maybe its the elimination of spaces???  '"& varSupportID &"' "
IT WAS THE SPACES THAT WAS MESSING THINGS UP....
Not working:   ' " & variable & " '
Working:        '"& variable &"'
Go figure
