Select By Attributes with VBScript
8189
10
05-22-2012 06:35 AM
SandraDema
Is it possible to programmatically select features by attributes  using vbscript?
I have introduced a unique identifier (not OID) to the attribute table that I need to search for, but i can't seem to find a method to do so.
I know this seems like a very simple question, but I have failed to find a good source of documentation pertaining to ArcPad and vbscript.
If anyone knows of such a source, please share.
Tags (3)
ThaiTruong
Probably  RecordSet::Find Method doesn't work for AXF file.  I don't have an axf file to test with, but you can try to use this code with your file to see if it works:
Dim objLayer, objRS, objRect, myQuery, myRec, myValue Set objLayer=application.map.layers("My Layer Name") myValue = 357799 Set objRS=objLayer.records If (Not objRS Is Nothing) Then  objRS.MoveFirst  For i = 0 To objRS.RecordCount - 1   If objRS.Fields("FieldName").Value = myValue Then    myRec = i+1   End If   objRS.MoveNext  Next End If  If (myRec > 0) Then  'Zoom to feature  Set objRect=objRS.Fields.Shape.Extent  Call objRect.ScaleRectangle(0.5)  Application.Map.Extent = objRect  Application.Map.Refresh Else  msgbox "Feature Not Found!" End If Set objRect = Nothing Set objLyr = Nothing Set objRS = Nothing Set pDS = Nothing
HannahFerrier
Hi Sandra,
If you have checked out your data from ArcMap using the ArcPad Data Manager, your project should already have a set of automatically generated Query Forms. These forms are the same as your Edit Forms, but are specifically used to search your data. On the Browse Toolbar (pointy hand on the globe) select the Find Tool (binoculars) to open your Query Forms. Here is an example from the Riverside Sample Dataset:
[ATTACH=CONFIG]14539[/ATTACH]
From here I can enter the ID of the Poles Record I am searching for and tap OK to see my Results Tab:
[ATTACH=CONFIG]14540[/ATTACH]
Now I can select my record and use the tools on the right-hand side to open the edit form, zoom to the record or navigate to the record.
All without writing a single line of code (my favorite!!)
For more info - check out this help article
HTH
Hannah Ferrier
SandraDema
Thanks so much for the reply.
I understand that I can use the built-in query feature. What I need is a way that I can query the data without user interaction.
I know that I can use SelectXY to search spatially when I have the XY coordinates. I'm sure there is a way to automate the query by attributes feature, I'm just coming up empty handed.
ThaiTruong
Since you have unique values in a field, you can try to use RecordSet::Find method to find a record that meets your search criteria.  The expression is a string in form: "[FIELD] = VALUE"
There will be one result is returned at each time you call the Find method.  And a return value of 0 tells you that no record was found.
ThaiTruong
This code snippet will help you get started.
In this example, it finds feature that [FieldName]="Lookup Value" from "My Layer Name", then zooms to that feature.
Sub SelectAndZoomTo
myValue = "Lookup Value"
myQuery = "[FieldName]= """ & myValue & """
myRec = objRS.Find(myQuery)
'If feature is found
If (myRec > 0) Then
 objRS.movefirst
 objRS.move(myRec-1)
 Map.Extent=objRect
'If feture is Not found
Else
 msgbox "Feature NOT Found!"
End If
Map.Refresh
End Sub
SandraDema
When I run your code, I get error 800A01BD - "Object doesn't support this action" at line
myQuery = "[FieldName]= " & myValue      (the field is an integer, so I removed the quotes)
When I use the same query string in ArcMap, everything works as expected.
Ideas?
ThaiTruong
Hi ssdema,
I don't see anything wrong with the above code or your expression string!  It should center the feature on your map.
Just double check to see your layer's name & Field name spelled correctly.
SandraDema
I am using axf files. I have read that the Find method does not work with previous versions of ArcPad when utilizing axf files.  Could this still be the case (explaining why I am getting this error)?
ThaiTruong
SandraDema
I did a little playing around with the code you provided and was able to get the search function to work the way i needed it to. i have included this code below.
I was a bit hesitant at first. The field crew will check out approximately 1500 features at a time. I thought looping though all of those features would be very slow.
As it turns out, the code runs relatively quickly.
Thanks so much to everyone who contributed.
Function SearchByAttributes(myValue)
Set objLayer=application.map.layers("LayerName")
        Dim I
        myRec = 0
  objRS.MoveFirst
    myRec = i+1
           Exit For
   End If
   objRS.MoveNext
End If
If (myRec > 0) Then
  'Zoom to feature
         Call objRect.ScaleRectangle(1.5)
                'select feature (feature must be in edit mode for the selection to work)
  objRs.Bookmark = Map.SelectionBookmark
Else
End If
Set objLayer = Nothing
Set objRS = Nothing
End Function
