scripting - How to tell if feature is being created or being edited?
1580
05-09-2013 07:21 PM
TereseRowekamp
I'm using VBscript. Is there a way to tell in my form load code if the edit form is being opened because the user is editing an existing feature vs creating a new feature?
Tags (3)
JamesNunn
Great,
By the way, why don't you tick the answer (or add your own answer with more details and tick that) to help others find and solve similar problems.:)
JamesNunn
Yes:
http://resources.arcgis.com/en/help/arcpad/10.0/sdk/scripting/ArcPadScriptingObjectModel~Form~Mode.h...
Dim thisform = Application.Map.Layers(lyrname).Forms('EDITFORM')
If lyrform.Mode = 2 Then
    Application.MessageBox('Form open for editing')
Else If lyrform.Mode = 3 Then
    Application.MessageBox('Form open for new feature')
End If
My vb is rusty, but you should get the picture.
TereseRowekamp
Thanks James. I eventually figured it out and got my code working as needed, but it's good to get the answer out here, too.
JamesNunn
Great,
TereseRowekamp
You know James, I've looked before trying to find where I check a reply as the answer and I never noticed the grayed out checkmark until right now when I looked again. Sorry I didn't mark your answer before!
