Sample CUT applet
881
07-07-2010 05:59 AM
D3EGPS
Hi all,
I was wondering whether someone has any experience with the cut applet sample available since ArcPad 8 in the developer sample. Indeed, I think that I am using it properly but I discover some issue with it and I did not find anything on the arcpad Esri forum about it !
It does not work properly or to be precise to make it work properly I have to use it once (make a cut for a line feature) and restart arcpad to do another 😉 which is not really simple 😉
Any experience with that?
I defined a pGDB with two layers :
1. the cutter
2. the feature class I am trying to cut into pieces...
I made an MXD file and extract data to ArcPad. I am using the ArcPad Data Manager to extract the data to an AXF file :
1. The Cutter as a background editable
2. The other feature class as a check-out layer.
When I try to cut a line, a create a new feature in the Cutter feature class and keep it selected. Switch the editable layer to the other line layer and use the cut interface available in the Applet. The line is cut.
When I try to do that again it does not work properly. The line that is split is not the one I want. I have to stop ArcPad and start it again to make it work normaly !
Any ideas ? Tips ?
Thanks
Regards
Julien
Tags (3)
