Post-Processing Quickprojects??
800
06-24-2010 12:27 PM
TonyCarricaburu
Is there a way to post-process Quickprojects? Sometimes its necessary to start a new project in the field, but without already creating a file thats GPS-enabled and attached to a geodatabase I am unable to come back to the office and post-process the results and achieve the higher levels of accuracy. GPSCorrect doesn't recognize the SSF file created by quickprojects.
Is this not an option?
Thanks in advance for any help.
Tony
Tags (3)
CarlBeyerhelm
The .ssf file that is created by GPSCorrect within ArcPad has to be post-processed using the Pathfinder Office Differential Correction utility, and then the ShapeCorrect utility in Pathfinder Office is used to apply those differentials to the QuickProject's shapefiles.
