Reference file paths in script on Mobile Devices
4780
01-11-2012 07:15 AM
JasonTipton
I have an Applet that automatically updates certain fields every time my user collects data. It was based on the XYZ+ script. My data is projected in UTM, but my users want to be able to record DMS as well. I found a script on the 15th page of http://arcscripts.esri.com/Data/AS15207.pdf that converts to DD.dddd. This is fine and it works great until I try and move it to my Nomad, because there is no C: drive. How do I reference a file at say "\\My Documents\gis\Coordinate System\NAD 1983 UTM Zone 15N.prj" ? "\" being the root directory.
Here's my code:
Sub FA  Set objRS = Map.Selectionlayer.Records objRS.Bookmark = ThisEvent.Bookmark  'define coordinate systems Set pLLCS = Application.CreateAppObject( "CoordSys" ) Set pMCS = Application.CreateAppObject( "CoordSys" )  'Set up Coordinate Systems  \\\\\-----This is where the problem is-----/////////// pMCS.Import("\\My Documents\gis\Coordinate System\NAD 1983 UTM Zone 15N.prj") pLLCS.Import("\\My Documents\gis\Coordinate System\North American Datum 1983.prj")   'Create Map Points and assign coordinate systems Set pMapPt = Application.CreateAppObject("Point") Set pLLPt = Application.CreateAppObject("Point") Set pMapPt.CoordinateSystem = pMCS Set pLLPt.CoordinateSystem = pLLCS 'Set x/y values for original point pMapPt.X = objRS.Fields.Shape.X pMapPt.Y = objRS.Fields.Shape.Y 'transpose the coordinate to lat long Set pLLPt = pLLCS.Project(pMapPt)  For Each f in objRS.Fields  Select Case Ucase(f.name)      CASE "LATSTRING"    f.Value = DMS(pLLpt.Y, "y")   CASE "LONSTRING"    f.Value = DMS(pLLpt.X, "x")   End Select  Next objRS.Update  Set pMapPt = Nothing Set pLLPt = Nothing Set pMCS = Nothing Set pLLCS = Nothing Set objLyr = Nothing Set objRS = Nothing End Sub   Function DMS(v, xy)  absV = abs(v)  degInt = Floor(absV)  min = multDenom(absV, degInt)  if xy = "x" then   degInt = degInt * -1  end if  minInt = Floor(min)  sec = round(multDenom(min, minInt),4)  DMS = degInt & " " & minInt & " " & sec   End Function  Function Floor(d)  dTmp = Round(d)  if dTmp > d then   dTmp = dTmp - 1  End if  Floor = dTmp  End Function Function multDenom(d, dInt)  d = d - dInt  multDenom = d*60  End Function
The code works fine. I just want to include it in case anyone else is trying to do the same thing, or has suggestions on more efficient way.  On the desktop I just change 2 lines to:
'Set up Coordinate Systems  pMCS.Import("C:\Program Files (x86)\ArcGIS\ArcPad10.0\Coordinate System\Projected Coordinate Systems\UTM\NAD 1983\NAD 1983 UTM Zone 15N.prj")  pLLCS.Import("C:\Program Files (x86)\ArcGIS\ArcPad10.0\Coordinate System\Geographic Coordinate Systems\North America\North American Datum 1983.prj")
So how do I reference paths on mobile devices that do not have a root drive letter?
Tags (3)
GarethWalters
Hi Jason,
I tend to write my scripts using Preferences.Properties("AppletsPath") so it doesn't matter if the script is on Mobile or PC.
Hope this helps.
Cheers,
Gareth
JasonTipton
Found the answer: http://social.msdn.microsoft.com/forums/en-US/netfxcompact/thread/3e73293d-eda5-43b0-8018-a191446439...
Basically, "\" is the root drive. I was on the right track, but instead of "\\" use "\" so change
"\\My Documents"
to
"\My Documents"
GarethWalters
Hi Jason,
Hope this helps.
Cheers,
Gareth
RolfBroch
Hi Jason,
Hope this helps.
Cheers,
Gareth
Hi Gareth, I would assume that the above is only true when you keep to having only one path defined in your applets tag in the config file and not as below
  <PATHS public="C:\Users\Public\Documents\ArcPad" data="C:\Temp\Data" applets="C:\Temp\Applets1;C:\Temp\Applets2" styles="" extensions="" templates=""/>
Rolf
GarethWalters
Rolf
Hi Rolf,
As the property is indexed, I could use Preferences.Properties("AppletsPath",2) to get to a specific folder.
Standard ArcPAd Data Path reads: C:\Users\Gareth\Documents,C:\Users\Public\Documents\ArcPad
Preferences.Properties("DataPath",2) would give me: C:\Users\Public\Documents\ArcPad
Cheers,
Gareth
RolfBroch
Hi Gareth, thanks for the information.
I actually did not know that the value was indexed (although it clearly says so in the ArcPad Help) and this opens up new possibilities for referencing files.
Rolf
