Quick Projects: Default Projection
1833
02-06-2011 07:45 PM
GrahamW
Very quick question:
Is there a way to set a defult projection when using a quickproject?
I'm happy to use a bit of code style hacking if need be for the individual template or set this arcpad wide.
Tags (3)
EricMcPhee
To set your default projection across all of ArcPad, you can take a .prj file and rename it to ArcPad.prj and place it in your "My ArcPad" folder on your device. This is for version 10, I think if you are working with an earlier version you would put the ArcPad.prj file in the "My Documents" folder.
EricMcPhee
MatthewRashty
THANK YOU SO MUCH! I've been looking everywhere for this answer
GrahamW
L E G E N D ! !
