Quick Fields Sequential ID
4347
08-18-2015 03:28 PM
JuneAcosta
I want to use the ArcPAD 10.2.2 Quick Field Sequential ID to populate the unique ID for our trees. Is there a way to set the starting number for the Sequential ID?
HannahFerrier
When you collect the first feature after enabling QuickFields with a Sequential ID, you will be prompted to enter the starting value. All subsequent features captured will increment from this initial value.
Hope this helps,
Hannah
HannahFerrier
Hope this helps,
Hannah
JuneAcosta
Hannah,
I turned QuickFields off and deleted the expressions, but the logic is still running in my .axf. How can I get rid of the functionality that seems to be embedded in my .axf?
June
HannahFerrier
QuickFields are only applied to the map (.apm) - not in the data (.axf).
When ArcPad is in Design Mode - selecting the QuickFields tool will allow you to add and remove expressions. Make sure that all of your expressions have been deleted;
When ArcPad is NOT in Design Mode - selecting the QuickFields tool will switch QuickFields ON and OFF for your specific map (.apm).
Make sure QuickFields is turned OFF for your map.
