Python scripting for ArcPad Checkin
918
09-13-2012 08:22 AM
RichardGwozdz
I can use ArcGIS Desktop (10.1) model builder to leverage the ArcPad Check In Tool. When I run the model it executes successfully. When I export the model as python I get this code:
import arcpy
# Local variables:
Test02_axf = "C:\\aWorkspace\\ESA\\ArcPad\\AXFs\\Test02.axf"
# Process: ArcPad Check In
arcpy.ArcPadCheckin_ArcPad(Test02_axf, "", "")
However, when I run this code in the python window I get:
Runtime error
File "<string>", line 8, in <module>
AttributeError: 'module' object has no attribute 'ArcPadCheckin_ArcPad'
And yes indeed arcpy has no function named ArcPadCheckin_ArcPad. So model builder must be exporting erroneous code.
Does someone out there know what the issue is here? Is there really anyway to do this operation with python?
Tags (3)
RichardGwozdz
it works with the old pre-arcpy solution
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Local variables:
gp.ArcPadCheckin_ArcPad(Test02_axf, "", "")
