Problem ArcGIS 10 making Arcpad files.
1083
03-09-2011 12:27 PM
JamesPrimm
When creating an arcpad file in 10 and you export your background data as shapefiles we're experiencing problems for the user in arcpad 7.1.1 and 10. If the user goes to find to search for say anything they are instantaneously kicked out of arcpad 100% of the time. When running tests I've found instead of shapefiles make the background data as "apx" files, this will make the search work without getting the good ole "Windows kick out", that windows is typically known for. But the problem is the files run about 10 times slower than files with shapefiles. It took one of my users in arcpad, 10 minutes to get his file up yesterday. When the file is first created it will open in about 5 seconds on our Panasonic Toughbook CF-19. I've experienced that apx files are horribly slow not sure if that's a glitch or if that's normal. It appears that the longer the file is worked in with apx background data the slower the file becomes. So has anyone had this problem?
Tags (3)
JuanLuera
I am including the check out/in work flow for ArcPad in case you feel that it was different in the previous versions of ArcPad that you worked in. this should give you a step-by-step work flow to take your data out, and make edits in the field and check them back into your database.
HowTo:  Check Out/In data from ArcMap to ArcPad for editing
http://support.esri.com/en/knowledgebase/techarticles/detail/32862
