Password hidden in input box
2399
06-11-2013 11:18 PM
JamesNunn
I am trying to create an input box for the entry of a private password, but there doesn't seem to be an in-built ArcPad function or object for replacing input text with asterisks. Is there a way of coding this, preferably in JS?
Tags (3)
DeniseKing
James,
Please look at the ArcPad Login Form sample described on ArcPad Team Blog, it's VBScript not JScript but should be enough information in sample applet to get you going with JScript. The ArcPad Login Form sample can be downloaded from ArcScripts at: http://arcscripts.esri.com/details.asp?dbid=16477. ArcPad Forums is another resource to get assistance with scripting from other ArcPad users.
Good Luck,
Denise
JamesNunn
Thanks Denise, I am using the Login form currently but it appears to lack the entry of a password - the user only selects their username and gets on with the work. I have an ftp connection setup which requires a password and I'd like a bit more secure password entry.
DeniseKing
James,
I didn't even notice the lack of password entry in the Login Form sample. I'll do some more research and post information when found.
Denise
ThaiTruong
To create a masked Password input field, open your form in ArcPad Studio, add an input text control to your form.  Then under the control properties, check on the "Password" check box.
Now, each character you enter in that text box will be displayed as asterisk (*).
To get the value of the input password, just use:
pControls("txtPassword").Value
where, "txtPassword" is the name of that control.
