ArcPad 10 will not use data that is defined as NAD83(2011) in ArcGIS. Anybody out there have the info to create the files for ArcPad so it will use NAD83(2011) data? Since the post processing base files correct the data to NAD83(2011), I would prefer the geodatabase feature classes be in that coordinate system right from the beginning, with the geodatabase set to NAD83(2011). As it is, the data is in NAD83(2011) after post processing, but it has to be defined as an older NAD83 in the feature class properties, and thus is inaccurate.
