My drop downs won't drop down
831
04-18-2011 06:18 AM
MichaelEtter
I am working on customizing attribute tables for data collection using ArcPad 10.  Everything was fine, but now my domain fields won't drop down.  After selecting the drop down menu a black line appears underneath the entry box and I can use the arrow keys to toggle between possible entries, but they do not drop down as a list.  Did I accidentally change some hidden menu option?
Thanks.
Tags (3)
JuanLuera
If you would like, please upload a small sample dataset to test with. Post a response when the data is ready, I will download it and test it for you.
Esri ftp site using the following procedure:
1) Zip data to be uploaded.
2) Open Internet Explorer and go to ftp://ftp.esri.com/
3) Go to the File menu > Login As and check the box labeled Login Anonymously.
4) Enter your email address as the password.
5) Open the 'pub' folder, then browse to and open the 'incoming' folder.
6) Create a new folder, and then name it the "with my name".
7) Then upload the data into it, and then email me that data has been uploaded.
**Please contact Esri Support for assistance and be sure to indicate "If you are current in ArcPad maintenance, please submit. Thanks!
http://support.esri.com
