Is there an easy way to populate fields in ArcPad from other reference layers?
1127
01-16-2014 10:14 AM
TimothyKing
I have some reference data that I am using for a survey i.e. sections, townships, testing areas etc. that i want to auto populate when I collect new point line or polygon data.  Does anyone know the best way to do that?  Any help would be appreciated.
Tags (3)
SumanChatterjee
You can write a method in the On  Form Load event. Get the X,Y of the location . Then to get  the point features get the distance to the point using FindNearestXY method of the Recordset object of the particular layer you are interested in. For polygon feature layer you can use the ISPointIn method to see  the point is contained within which polygon .
Once you get the feature yo can easily  populate the fields in the form using the fielld values.
Suman
