Installing ArcPad 10.0.3 Python Not Found
2514
11-09-2011 08:25 PM
DavidRobinson4
When I install the ArcPad 10.0.3 version on my Windows Vista 64 U;timate (AMD 1090T Processor) the install routine tells me that Python is not detected and will not completely install the ArcPad toolbox set.
I have tried 32 bit versions of Python from 2.6/6 to the 3.2 (latest version) for windows 32 and and Windows Vista 64.
I have tried the versions compiled for 64 bit code -- 2.7.2 through 3.2.? (latest)
And Yes I did read the directions and installed the corresponding PyWin as well for each install.
Can anyone suggest a solution to this?
Is this a bug?
Is a specific version require?
Is a specific installation location required?
Tags (3)
JuanLuera
David,
Thanks for the update on your python issue and I have not seen this issue with regards to installing ArcPad 10.0 SP3 and python. I would love to work wiht you through this issue, and we feel it would be better if you would log a support incident with us. You can add a note through the Webform that we talked via the forums and I suggested fror the incident be routed to me. Thanks David!!
DavidRobinson4
David,
Juan:
I would love to. We bought ArcPad through the Mexican Distributor.
http://www.sigsa.info/sigsa/
BTW their English skills are minimal and my "Spinglish" skills are barely passable so it makes for interesting conversations if your suggestion is that I deal with them for support. 🙂 But if that's the way it's gotta be...
Bottom line: We do not seem to have any support account with ESRI. I checked our email record just now.
This is because we have installed the ArcPad on our Trimble GeoXH purchased and used in Mexico. I am currently sitting here in Canada testing all the software before I head out to the offices shortly and do not even know if I can use our license number to do a full install and test here -- before I head out.
Since you are with ESRI presumably you can email me through the account on my WebSite registration.
I will do what I can to assist.
If the "solution" is to work with Windows XP -- that is not on the table. If it is an issue where I must upgrade this system in Canada to Windows 7 I will do that asap!
Cheers y hasta luego.
