Indexing string field script causes Arcpad crash
534
11-27-2013 04:49 PM
SteveFitzgerald
I'm trying to add/remove shapefile indexes using a vbscript in Arcpad 7.01 or 8.0 (sp 4).
I've only tried it on Windows 7 and XP and it causes Arcpad to crash on both occasions.
It crashes when attempting to add the index. The progress bar appears and just stays there (win 7 calls a crash while xp is happy to leave it at that).
When Arcpad is opened again it has actually created the index and it can then be deleted using the code with no problem.
Any ideas welcome!
Function DoIndex
 Dim theMap, rs
 fieldName = "Name"
 Set theMap = Map.Layers("trees.shp")
 Set rs = theMap.Records
 If rs(fieldName).HasIndex Then
  If theMap.CanEdit = True then
   DoIndex = rs(fieldName).DeleteIndex
   msgbox "Index deleted!"
  Else
   Msgbox "Layer " & theMap.Name & " cannot be set to edit mode!",vbInformation,"Layer not indexable"
   DoIndex = False
  End if
 Else
   DoIndex = rs(fieldName).BuildIndex
   msgbox "Index built!"
  Else
   DoIndex = False
  End if
 End if
 Set rs = Nothing
 Set theMap = Nothing
End Function
Tags (3)
