Image Control Help
1355
08-19-2010 06:01 AM
JayKappy
I placed an image control on my form and am trying to populate it by a simple click of a button.  I will modify the launch and image change later, for now I just want to see the image.
ERROR:
Object does not support this object or method
I tried it 4 ways (seen below) :
Sub Image
     Dim Image1
     Set Image1= Applet.Forms("Supports").Pages("Page2").Controls("Image1")
     Image1.Value = "C:\Temp\Streetsign_Database_LatLong\Images\R1-3.jpg"
End Sub
Sub Image
     Dim Image1
     Set Image1= Application.Applets("Custom Settings").Forms("Supports").Pages("Page2").Controls("Image1")
End Sub
Sub Image
     Dim Image1
     Set Image1= ThisEvent.Object.Pages("Page2").Controls("Image1")
End Sub
Sub Image
End Sub
Any thoughts?  Just want to show an image on the form determined by a field value...as I said for now just want to place any image in there....
THanks
Tags (3)
JayKappy
I also tried: But no luck
Dim pTheImageBox
Set pTheImageBox = Application.Forms("Supports").Pages("Page2").Controls("Image1")
pTheImageBox.Value = "c:\Temp\Streetsign_Database_LatLong\Images\R1-3.jpg"
JayKappy
Anyone ever use a image control?
Anyone out there offer some advise here....I can figure this out for some reason....
JayKappy
I can get the image controls name with this....but it errors out when I try and set the image value...
Any thoughts
Dim objRS, objSelLayer, objEFPageOneControls4, objEditForm4, objEFPageOneControls2, objEditForm2
Set objSelLayer = Map.SelectionLayer
Set objRS = objSelLayer.Records
objRS.Bookmark = Map.SelectionBookmark
Set objEditForm4 = application.map.layers("Supports").forms("EDITFORM")
Set objEFPageOneControls4 = objEditForm4.Pages("page2").Controls
Dim varobjectid
varobjectid = objEFPageOneControls4("objectid").Value
msgbox "varobjectid: " & varobjectid
Dim imagename
imagename = objEFPageOneControls4("Image1").Name
msgbox "Image name : " & imagename
Set objEFPageOneControls4.("Image1").Value = "c:\Temp\Streetsign_Database_LatLong\Images\R1-3.jpg"
JayKappy
GOT IT:
Dim varfilepath
varfilepath = "C:\Temp\StreetSign_Collection_ArcPAD\Images\"
Dim varimagename
varimagename = "R1-3.jpg"
objEFPageOneControls4("Image1").Visible = True
objEFPageOneControls4("Image1").Enabled = True
objEFPageOneControls4("Image1").Value = varfilepath & varimagename
