i have a smartphone with version 6 android and i can't download the collector app. Is there an alternative app that i can use to collect the data in the field and bring it back to Arcgis
2282
8
09-24-2018 05:29 AM
PatrickFlynn4
I have a smartphone with version 6 android and i can't download the collector app. Is there an alternative app that i can use to collect the feature and location data in the field and bring it back into Arcgis.
deleted-user-qpvAI3Fo0MKR
According to the Esri documentation Collector is supported on "Android 4.2 (Jelly Bean) or later".
PatrickFlynn4
Hi, thanks for that, i read that myself about Jelly Bean prior to posting.
You can use a Garmin to collect waypoints and then use the Minnesota DNR tool to convert to .shp -> Arc.
PatrickFlynn4
That's great, but I don't want to buy another device.
Thanks for the advice.
StephenQuan1
Hi Patrick,
I noticed that you posted your question in the ArcPad GeoNet forums?
That being the case, let's answer the ArcPad support part. ArcPad runs on both Windows and Windows Mobile devices. Of which your present device is neither. If you wish to run ArcPad on Windows, there are a number of very functional Windows devices out there ranging from inexpensive to most rugged. As to running ArcPad on Windows Mobile support, people tend to go for high precision offerings through Esri Partners such as Esri Partners | Trimble | GeoCollector for ArcPad
The other part of your question is what can you run on Android? Esri offers quite a number of solutions:
Some of these run on multiple platforms, i.e. Android, iOS, Windows, macOS, ...
If these applications don't quite fit your requirements, you can build a custom application from either templates or from ground up:
Stephen
PatrickFlynn4
Hi Stephen,
thanks for that pretty comprehensive answer. Im not very tech savvy, and
didnt even realise i posted originally in a particular section, i thought
it was just "the arcgis forum". Just 1 more thing, when i said data, I
meant collecting features like bins and lampposts and trials. Is that still
possible with those straight out of the box options like 123 ? Designing
my own app is a bit beyond my tech level much as I would love to have the
skills. (You can teach an old dog new tricks, but don't try and get him to
build an app )
StephenQuan1
Hi Patrick,
All the products that I mentioned will implement your use case. The devil is in the detail.
As you indicated your not tech savvy, I'm tending to think that Survey123 may be a good fit for you in terms of ease of use and flexibility. Using Survey123, is um, "as easy as 1-2-3"? Hope that didn't sound too corny. I highly recommend you give it a go and I believe you will achieve success with the shortest time investment. You already have access to all the hardware that's needed. A desktop PC that's capable of editing Microsoft Excel files (runs on Windows, macOS and Linux) to prepare your forms. A mobile device (runs on Android, iOS, Windows Phone, Windows, macOS and Linux) to collect your data in the field. As far as software's concerned, in addition to installing Survey123 and Survey123 Connect, you will need Microsoft Excel and an ArcGIS Online account. There's plentiful material on YouTube and GeoNet and the Survey123 official website itself.
However, be aware that when it comes to all software I've recommended it is still a case of choosing your "horses for your courses". There is no one best answer. Each have their unique pros and cons. Your mileage will vary with the different apps, so, please give them all an open mind and see which one is a best for for you.
Stephen
PatrickFlynn4
OMG,
That is awesome, thanks very much for the detail, I appreciate it a lot. I
hope you have a really great day.
Thanks so much,
