How to view raster layers with floating points
1038
07-13-2011 03:59 AM
AndreasNielsen
Hello.
I hope someone can come up with an idea to this one:
I have a raster layer (image) in my ArcGIS with pixel values between -1 and 1, which I need on my ArcPAD tablet. If I transfer the image to ArcPAD with the arcpad-tool, the data is not visible (most likely due to the low values (in the sense of digital numbers...), yet the tablet reads the data, because I can get info about coordinates, projection etc. That's problem number one.
The second issue is that I need to get info about specific pixel values. If I choose the "Identify" option, I only get info about coordinates...
Any help would be much appreciated.
Thanks.
Tags (3)
AndreasNielsen
Hi again.
I solved the graphical viewing of the data by using Raster Calculator in ArcGIS to multiply the values, so instead of being between -1 to 1, they are between 0 and 200.
However I still can't find out how to get info about pixel values in raster layers.
Any ideas??
