Help: Trying to Add points to shapefile
1001
10-28-2013 05:43 AM
CraigGraham
Good Morning,
I'm trying to add points to a shapefile in ArcPad.  I found this script example that does it from the position of the mouse pointer....
Set objPoint = Application.CreateAppObject("Point") Set objRS = Map.Layers(???<<Layer Name>>???).Records Call objRS.AddNew objPoint.X = Map.PointerX objPoint.Y = Map.PointerY Set objRS.Fields.Shape = objPoint objRS.Fields ???<<Field Name>>???).Value = CStr(???<<Information or Variable>>???) objRS.Update
I made some alterations to it so that it is looking at the X and Y values from photos in a folder.
' Snipped is a bunch of code creates a shp, then in a loop... opens the image, reads the lat/long and projects it to the current map's projection. Set pPoint= Application.CreateAppObject("Point") Set rs = Map.Layers(sPhotoSHPLayerName).Records Call rs.AddNew pPoint.X = dProjectedX pPoint.Y = dProjectedY Set rs.Fields.Shape = pPoint rs.Fields "PhotoName").Value = CStr(file.name) rs.Fields "Long").Value = CDbl(dLong) rs.Fields "Lat").Value = CDbl(dLat) rs.Update
I keep getting a very unhelpful error message at "Set rs.Fields.Shape = pPoint".  It says something like "Unavailable".  Does anyone know what I'm missing.
I have messaged boxed dProjectedX and dProjectedY and they are valid coordinates that make sense for the study area.  The reference to sPhotoSHPLayerName seems correct.
I feel like this is the one little step I need to finish to get this project over with.  At this point all suggestions will be tried.  Thanks in advance for any help.
Take care,
Craig
Tags (3)
CraigGraham
So the example on the ArcScripts site is likely out of date.  With 10.1 the following works great.
Set pPoint= Application.CreateAppObject("Point") Set rs = Map.Layers(sPhotoSHPLayerName).Records pPoint.X = dProjectedX pPoint.Y = dProjectedY rs.AddNew pPoint rs.Fields "PhotoName").Value = CStr(file.name) rs.Fields "Long").Value = CDbl(dLong) rs.Fields "Lat").Value = CDbl(dLat) rs.Update
Have a good day.
CraigGraham
Have a good day.
