Hi
Just after a bit of advice please. We have just purchased a couple of these from a neigbouring water authority and I'm struggling to figure out how to set the com ports up etc.
If I just want to use the device with the internal antenna (30cm accuracy) do I set the com port up in the GPS controller program and do I then need to do the same in ArcPad or will arcpad pick the settings up from GPS controller.
The other thing I can't figure out is if I plug the Zephyr antenna in, does it automatically switch to using that antenna or do I need to do something in the com port settings to tell it to use that one rather than the internal antenna.
Is there a visual way to see what the accuracy is on the device itself rather than capturing data twice using the two different antennas and comparing the two ?
Thanks in advance.
