Generate unique id/way point?
5813
15
04-22-2010 07:00 AM
jeremysarrow
Trying to have a point shape file that generates a unique id in arc pad while collecting data in the filed.  I know there is the Object ID number but this does not show up until after you are done entering data.  I basically need a unique id like a way point that the field person can see while entering the data and write down in their field notes as well.
Any ideas greatly appreciated.
Tags (3)
RolfBroch
ArcPad can generate a unique id using
strID = System.CreateGuid
request.
Rolf
jeremysarrow
Rolf, I'm a bit of a novice with ArcPad.  Would I do this script in ArcStudio in the axf file on the desk top, create a new field for the unique ID and then load it into the Trimble unit?  Thanks for any additional guidance on how to do this.
JayKappy
Rolf
Is it as simple as:
Dim Test
Test = System.CreateGuid
How is this number being created?  I have code that grabs the max ID from a field and adds 1 to create a new id, but am interseted in this approach....
Looking to test time differences on the Juno unit to see which is more eficiant...I would imagin eht eCreateGuid would be since I dont hav to build and run the SQL query....
Any thoughts to how the CreateGuid is created?
Thanks
JayKappy
jsarrow....yes you would have to do it in ArcStudio.....I can show you but basically if this is workign as I think:
OnFormOpen you would declare a global varaiable.
This use this varaible to populate a textbox that is set to the UNique attribute.....
Something like this:
In ArcStudio under Feature Layers you should see the layer you are going after.  Double Click it
This will open the design mode for the form
when you open the form in design mode click Form Tab and properties.
There is then a Events Tab
CLick this and then click "OnLoad"
In the box write:  Call UniqueID
This will be the Sub routine you will create later
Close this dialog but not the one for the form....THere is a little blue script in the tool bar (edit script)
Click this to create a new script page.
In that script page do something like this.
NOTE:
Outfalls below is the naem of the layer that I am going to be updating....
page1 is the page number, or the tab number...depends on how many tabs you have and which one....you can click the tab in design mode and click "Page" "Properties" then Name is what you would use there....it defaults to (page1, page2, page3 etc)
In the script page place this code there...on load it should call this sub routine, create the unique id and assign it to the textbox of your chooseing...when you close the record this will be assign to the field attribute
In my case:
Outfalls is the feature class I am updating
its on page1 or the first tab
Edit1 is the name of the textbox I am updating on page1
Option Explicit
Dim varUniqueID
Sub UniqueID
 ' CREATE THE VARAIBLE AND ASSIGN IT THE CREATED GUID
 ' Dim createUniqueID
                ' I commented this varaible out because I delclared it global above in the option explicit...you can delete the global varaible and declare it here if you want...
                ' globally you can do other stuff with it...
 varUniqueID= System.CreateGuid
 ' NEXT YOU HAVE TO GRAB THE FORM PAGE AND ASSIGN THE VARAIBLE TO THE TEXTBOX
 Dim objRS, objSelLayer, objEFPageOneControls3, objEditForm3
 Set objSelLayer = Map.SelectionLayer
 Set objRS = objSelLayer.Records
 objRS.Bookmark = Map.SelectionBookmark
 Set objEditForm3 = application.map.layers("Outfalls").forms("EDITFORM")
 Set objEFPageOneControls3 = objEditForm3.Pages("page1").Controls
 objEFPageOneControls3("Edit1").Value = varUniqueID
End Sub
JayKappy
My only thought on that....I jsut tested it and it works...is the long number.
I am using my Unique ID to create photo names etc.  If you have a 30 digit number in front of the image it makes things tough....
On forom load I simply query my feature class and find the Max number in a number field.
I then add 1 to the number and assign it as the new Unique number...
This way I have can rename my images to something like this
Unique ID _ Field Name _ Time Stamp . jpg
Then in ArcGIS I can click a feature and get its unique ID, then query a folder for all images that start with that unique number.
Just a thought
jeremysarrow
Thanks for all the detailed info jay.  I'll give it a try and let you know how it works out!
DaveAlmond
All-
We gave up on relying on ArcPad to generate unique IDs for us and simply use the Julian Date (yymmdd +24:00 time) which also allows us to sort our files by date/time of creation.  You could add seconds if you 're blazing through more than one feature per minute, but the best part....no coding necessary!
KearyHowley
Hi Stormwater12,
I tried to use the AXF data/time stamp to implement your recommended Julian Date (yymmdd +24:00 time) method to log a unique feature ID.  This works fine on ArcPad in the field.  The issue I'm having now is the values are being dropped when I check the data back into the file geodatabase.  Have you experienced this issue?  A little more inof on how you set this up would be appreciated.
Thx
DaveAlmond
We simply created a field for out unique ID and enter it manually. So if I was entering the unique ID at the time of this writing, I would simply enter 1107271120 for 11-year, 07-Month, 27-day, 1120- hour. It requires typing with each feature created, but it is simple.
