FindNearestXY from GPS or pointer
1178
04-23-2010 07:07 PM
CharlottePeters
How can I use code to identify whether a point was added using the GPS or the stylus? Right now, when a user creates a new point with the stylus, an attribute value from an underlying shapefile at that location is stored in a variable and then entered in a control on another shapefile. The stylus method works fine, but I need to allow the user to add a new point using the GPS tool. I was thinking of using an If...then statement, but I don't know how to recognize X/Y coordinates collected using a stylus vs. GPS. I use the following code for the stylus:
cRS.BookMark=Application.Map.SelectionBookmark
  Set cShape=cRS.Fields.Shape
gRec=gRS.FindNearestXY(cShape.x, cShape.y)
To determine if the point was added with a stylus or GPS I tried the following, but the stylus method always returns the value of where the GPS is currently located and not where the stylus was tapped.
If GPS.x>0 then
  dblX=GPS.x
  dblY=GPS.y
 Else
 End If
If GPS.x>0 then '
  gRec=gRS.FindNearestXY(GPS.x, GPS.y) '
 Else '
 End If '
My intent is to allow the user to collect a point with a stylus even when the GPS receiver is on. IsValidFix and IsOpen automatically generate GPS.x and GPS.y when I want to wait until the user taps the GPS point button before populating GPS.x and GPS.y. I thought about the OnPosition event, but know how to use that in code.
Any guidance would be appreciated.
Charlotte
Tags (3)
RobChouinard
Is this what you are looking for?
Sub CapturePointerXY()
     'Get X,Y From Pointer
     Dim X, Y
     X = Map.PointerX
     Y = Map.PointerY
     'Do something with this captured location
End Sub
What I did was setup a new toolbutton and called "CapturePointerXY" from the "onpointerup" event. This makes a custom PointerMode the same name of the toolbutton. Search "PointerMode" on the ArcPad Help Index for more info on PointerModes.
Hope this helps.
