Error Status From GetDataFromArcPad
4663
08-31-2015 08:45 PM
khadijahnas
Hi, I want to get an extra explanation the reported errors below. The confusing here is that the polygon on ArcPad looks fine and close properly. Can anyone help?
1 out of 1 AXF files were processed.  Here are the results:
* The selected layers in C:\Users\gdasgdbadmin\Desktop\yusuf\AF44064_afterSync\DataForArcPad\DBO_FieldworkGroup2_KC2_4_5K_gdasgdb.axf were successfully checked in, but one or more edits were skipped because the geodatabase reported an error. The first error reported is:
Polygon does not close properly
The following XML document lists all ArcPad edits that were replayed against the source geodatabase.
Please click the ? button and then click this report for more details about the XML format.
<?xml version="1.0"?>
<CHECKIN>
   <CHANGE tablename="B_RECREATIONAL_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
   </CHANGE>
   <CHANGE tablename="B_INSTITUTIONAL_BUILDING_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
   </CHANGE>
   </CHANGE>
   <CHANGE tablename="B_COMMERCIAL_BUILDING_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
   </CHANGE>
   <CHANGE tablename="B_BUILDINGS_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   <CHANGE tablename="B_BUILTUP_BUILDING_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
   </CHANGE>
   </CHANGE>
   </CHANGE>
   <CHANGE tablename="U_ELECTRICAL_STATION_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
   </CHANGE>
   <CHANGE tablename="U_COMMUNICATION_TOWER_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
   </CHANGE>
</CHECKIN>
HannahFerrier
This is a known issue in ArcPad - the z-value for the closing point of a polygon is not set correctly.
This can be worked around by manually copying the z-value for vertex 0 into the z-value column for the last vertex.
Now for the good news - this issue will be resolved in the next ArcPad update, so your workarounds will only be temporary
Hannah
khadijahnas
Hai Hannah,
We are facing this problem when collecting data using ArcPad 10.2.1 with GPS Correct. How about if we are using ArcPad 10.2.2 with GPS Correct? Have you heard the compatible of them? I have test the latest version of ArcPad 10.2.2 with Trimble Position and its looks fine.
HannahFerrier
Hello,
Please see the following document: http://trl.trimble.com/docushare/dsweb/Get/Document-160913/ProdCompMatrix_September2015.pdf
It specifies product compatibility for Trimble products.
If you do have any issues using ArcPad with GPS Correct - please contact Technical Support.
- Hannah
FadzlanAbdul_Jabar
Hello Hannah,
May I know when is the next ArcPad update will be available ?
HannahFerrier
We are working very hard on the next release of ArcPad as we speak - I can't give you an exact date but I would expect the next version will be available in early 2016.
