Error Opening ArcPad on TopCon GPS Unit
917
02-14-2012 11:03 AM
PhyllisDavis
I am using ArcPad 10 on a TopCon GRS-1 unit and haven't had any problems until yesterday.  When I ArcPad on the unit I recieve the error:
a problem has occurred with ArcPad.exe
and the error log says:
   EvntType: WinCE501bExceptio
   AppNam: ArcPad.exe
   ModNam: coredll.dll
   OwnName: ArcPad.exe
any suggestions other than uninstall/re-install ArcPad??
Thanks in advance!
Tags (3)
MicheleMattix2
I haven't work closely with the GRS-1, but on other GPS units a hard reset often resolves this problem.  Check the user manual to see how to do this.  It's worth a try.  If that doesn't work, I would uninstall (reset to factory settings) and re-install.
Good luck!
